Results 1 to 5 of 5
Thread: Crop image in pdf
  1. #1
    Join Date
    Jun 2010
    Posts
    42
    Default Crop image in pdf
    Hello, how can I crop an image that I inserted into my pdf?
  2. #2
    Join Date
    Feb 2011
    Posts
    174
    Default
    I think cropping images might only be available in version 9 and higher but find the "crop image" tool or select the image and then go to the properties panel and click the "crop" button in the Appearance section of the properties.
  3. #3
    Join Date
    Apr 2010
    Posts
    285
    Default
    If you're running a version below 9, you could take a snapshot of the area you want, and replace your original with the pasted snapshot.
    Actually, I think that's pretty close to how the crop tool works in PDF Revu. I would prefer a crop tool that would show handles on a selected image, so you could adjust the cropping before committing the crop.
  4. #4
    Join Date
    Jun 2010
    Posts
    42
    Default
    I am using using version 7.0.0. So as I understand, no built-in crop tool is available. I don't see the "crop image" tool in the properties panel / Appearance section. I think that's for more advanced versions of BB.
  5. #5
    Join Date
    Dec 2009
    Posts
    201
    Default
    Crop Image was added in Bluebeam 9.
