Go Back   Bluebeam Community Forum > Workflow > Workflow
Reply
Thread Tools Display Modes
  #1
Old 03-15-2012, 02:46 PM
wizeguy wizeguy is offline
Junior Member
Default Combining out of Sequence pdfs...
I'm combining pdfs from AutoCAD and Revit. These will be placed into a folder as individual pds. We currently have 96 of these, and will be creating a combined pdf several times (thru out the life of the project). Now the catch. Say we have pdfs named A B C D E F G.
Each time we combined them we need to rearrange the sort order. We need them in a sequence B A C G E D F (I wish I was better at scrabble or I could do some funny word here, anyhow...).
So two thoughts. I wish there was a way to build the order within stapler, then save that import order.
Two perhaps there is a way I could pass along a command line to stapler? I could build the script once then run it several times?
Any pointers would be greatly appreciated.
  #2
Old 03-28-2012, 09:57 AM
BB BrianF BB BrianF is offline
Bluebeam Software
Default
Hi wizeguy,
If I understand you correctly, you are using the same sequence of files in each combination, and these files have the same "name.pdf."
What you can try is to organize the files in a way that you want and save the Stapler Job. This is basically an XML file that stores your settings and the Name/Order of PDF files. These all reference back to the source folder where you initially pulled the files from.
It's possible that if you simply replace the previous files with new ones using the same name, it will compile a new document for you. Just be careful about accidentally overwriting important files.
  #3
Old 03-28-2012, 10:14 AM
Junior Member
Default
Brian I think that will work great. I never noticed the ok button in the Stapler dialog box. I'm so use to just hitting the "create file" button instead. Thanks for the pointers. I figured it would have to be in there somewhere.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright © 2002 - 2012 Bluebeam Software, Inc. All rights reserved.
